My new to me (2 weeks) 05 Speedmaster with 4k miles recently suffered the dreaded idler gear boss failure when I went to start it last week. I removed the clutch cover last night to check after the whirring starter symptoms and low and behold both the engine crank case side and the clutch cover idler gear boss's were destroyed. And what-a-ya know, both apparently either broke or cracked previously because they were both welded (sloppily) and the welds broke on me, the new owner, before I even had a chance to ride the friggin thing!!
I'm so pissed I can't see straight.
The guy I bought it from said he was the third owner and has only had it since April of 19 and denies any knowledge or responsibility for the issue.
So now I have a situation on my hands and sure would like some input and advice on the subject.
Do I
1) Attempt to get it repaired? From what I've read here and based on the fact that about half of each boss broke away where they were welded, it would be almost impossible to fix??
2) find another good 05 motor somewhere and make sure it hasn't been repaired and install a TTP Safe-start and be good from there ? I've seen a couple available for around 1200-1500.
3) find a good 07 motor that has the factory reinforced case and cover, much more expensive though. Also, if the newer motors are EFI, will that work in my bike with the electronics difference?
4) Sell the bike as-is for parts and lick my wounds and call it a day. This is a last resort as I want to keep the bike if financially feasible.
Help!!!!
Tom
