2006 Tiger 955i- electrical issues.
DaveyBoy
Riding for 37 Years
Today, 12:18
Jan 19, 2020
65
East Sussex
David
Triumph Tiger 955i 2006
I have just replaced the battery and started the bike no problems. I disconnected the battery to connect the sat nav and charging leads. Now I only have lights, horn, indicators but no ignition lights. I suspect it may be the main fuse that has blown by possibly short circuiting it when I reconnected the battery second time around. All other fuses are ok located under the pillion seat but I cannot locate the main fuse to check. I understand it is a 30A fuse. Where is it located?
Qship
Riding for 40 Years
Today, 08:18
Feb 25, 2014
4,276
478
Steve
'17 Tiger Explorer XRT
Hopefully someone that owned one of these models will be along shortly to help you out.
Linkdog
Riding for 13 Years
Today, 07:18
Jul 22, 2019
88
17
57
Groveland,FL.
Kevin
2010 Thunderbird 1600
I presume that if the main fuse ( directly off the battery ) was blown nothing would work.
DaveyBoy
Riding for 37 Years
Today, 12:18
Jan 19, 2020
65
East Sussex
David
I was taking into a account a comment made on another forum that stated that the 'main fuse' was separate to the fuse box situated under the pillion seat. I agree one would think as you have stated.
VABird
Today, 07:18
Nov 24, 2015
88
17
65
Virginia USA
Bob
2012 T-Bird 1600 ABS
The 30 amp main fuse is separate from the fuse box. It is mounted on the left side of the battery box, but as Linkdog said, nothing would be powered up at all if it has blown.
Trace back everything you touched. It is 99.99% there.
BTW, what are "ignition lights"?
ALSO, test the fuses with an ohm meter. Sometimes, they look ok but are not.
DaveyBoy
Riding for 37 Years
Today, 12:18
Jan 19, 2020
65
East Sussex
David
The lights that appear when the key is in the 'ignition on' position. Oil lights, brake lights etc
VABird
Today, 07:18
Nov 24, 2015
88
17
65
Virginia USA
Bob
That is on fuse #5. I don't know how you connected your charger pigtail & GPS, but it seems that you blew that fuse. Check it with an ohm meter, or if you don't have one, just try switching it out with a known good 10 amp fuse..
DaveyBoy
Riding for 37 Years
Today, 12:18
Jan 19, 2020
65
East Sussex
David
Will get onto that first thing in the morning. Let you know how it goes. Thank you.
DaveyBoy
Riding for 37 Years
Today, 12:18
Jan 19, 2020
65
East Sussex
David
Joy in abundance!! removed all fuses and checked. All seemed ok so replaced then and it has started. All I can think of is that I must have disturbed the fuses when putting the seat back on somehow. I don't really know what I did but it fired up straight away. Thanks for the tip.
VABird
Today, 07:18
Nov 24, 2015
88
17
65
Virginia USA
Bob
Glad to hear it.
I love it when it's a simple fix.
As I said, there are seldom "coincidences" when you finish a job and suddenly something else doesn't work. Always retrace your steps to find out how you buggered it up.
(How do I know this?:y49: )
