2019 Triumph Rocket 3 R/GT | First Look Review
DaveM
Rock & Roll
Premium Member
Today, 16:59
53,148
1,327
Dave
Speedmaster
Riding Since
1974
Triumph Rocket 3 R and Rocket 3 GT
Triumph has given its Rocket 3 muscle bike a major makeover, with the new Rocket 3 GT touring cruiser (left) and Rocket 3 R roadster (right) both powered by a 2,458cc in-line triple. (Photos courtesy Triumph)
In the late ’90s and early aughts, there was a displacement war going on among cruisers, with engine sizes growing from 1,449cc (Harley-Davidson Twin Cam 88) to 1,510cc (Victory 92C), then up to 1,670cc (Yamaha Star Road Star), 1,795cc (Honda VTX1800) and finally, breaking the two-liter barrier, 2,053cc in the Kawasaki Vulcan 2000, which debuted for 2004.
Triumph Rocket 3 R
Both Triumph Rocket 3s roll on new lightweight cast aluminum wheels shod with Avon Cobra Chrome tires. The rear is 240mm wide.
The following year, Triumph came along and topped them all with the Rocket III, which got its thrust from a massive 2,294cc in-line triple, albeit with an extra cylinder compared to the more traditional V-twins. But, just as a hippopotamus doesn’t have many teeth but the ones it does have are truly impressive, the Rocket III’s 4-inch cylinders were the same size as those in a Chevy 350ci V-8.
The Rocket III’s was – and continues to be – the largest engine of any mass-produced motorcycle, and when we strapped it to the dyno back in 2005, it spun the drum to the tune of 127 horsepower and 141 lb-ft of torque – an unheard-of amount of grunt that has only been beaten by a more recent version of the Rocket III. The 2010 Rocket III Roadster made more than 160 lb-ft of torque.
Triumph Rocket 3 R engine
Arranged longitudinally, the Rocket 3’s liquid-cooled 2,458cc in-line triple has three massive cylinders, three hydroformed exhaust headers exiting on the right side and a pair of howitzer-sized mufflers.
Of course, if you’ve been paying attention, then you know that Triumph recently unveiled the Rocket 3 TFC, a $29,000 limited-edition Triumph Factory Custom that was a major reboot for the Rocket 3 platform, and it’s powered by an even bigger in-line triple displacing 2,458cc and making a claimed 168 horsepower and 163 lb-ft of torque. At nearly 2.5 liters, the new Rocket 3’s engine is larger than that of many automobiles. The Rocket 3 TFC is also a much more modern platform than its predecessor (which is probably why the “III” was replaced by “3”), with updated styling, an aluminum frame, a single-sided swingarm, carbon fiber bodywork and a full suite of electronics.
Now Triumph has unveiled two production models, the Rocket 3 R and the Rocket 3 GT, the latter aimed at those who like to travel longer distances, with or without a passenger. Claimed engine output is 165 horsepower and 168 lb-ft of torque, in a package that weighs nearly 90 pounds less than the previous-generation Rocket III.
Triumph Rocket 3 R
The Triumph Rocket 3 R is a roadster with height-adjustable midmount foot controls.
Mass-optimized performance enhancements to the liquid-cooled engine include a new crankcase assembly, a new lubrication system with a dry sump and integral oil tank and new balancer shafts, which makes the new, larger engine 40 pounds lighter than its predecessor. On the right side is one of the Rocket 3’s most eye-catching styling elements – a trio of hydroformed exhaust headers leading to a pair of howitzer-sized mufflers, which Triumph says produce a “unique deep growling triple” soundtrack.
Triumph Rocket 3 GT
The Triumph Rocket 3 GT is a touring cruiser with a lower seat height, fore-aft adjustable feet-forward controls and a standard passenger backrest.
The engine is mated to a 6-speed transmission with a torque-assist clutch, and all that asphalt-buckling power reaches the rear wheel through a stout driveshaft. Throttle-by-wire and an IMU support a host of electronic features, including four riding modes, cornering optimized ABS and traction control, cruise control and hill hold control.
Triumph Rocket 3 R Brembo brakes
Big bikes need big brakes, and the Rocket 3s have a pair of top-shelf Brembo Stylema monoblock calipers up front, and cornering ABS is standard.
Slowing down the Rocket 3 are top-of-the-line Brembo Stylema monoblock front calipers, and its adjustable fork and rear shock are made by Showa. New lightweight cast aluminum wheels are shod with Avon Cobra Chrome tires, and the rear a full 240mm in width.
Triumph Rocket 3 R TFT display
Fully modern in every sense, the new Triumph Rocket 3s have TFT instrument displays and a full suite of electronics. Monza-style gas cap is one of many premium styling touches.
The Rocket 3 leads the way with a pair of round headlights that have been a signature styling feature of many Triumphs since the Speed Triple was introduced in the mid ’90s. Lighting is fully LED with daytime running lights. Other standard features include a TFT display, a USB charging port and keyless ignition and steering lock.
Triumph Rocket 3 R headlights
Like many Triumph models, the Rocket 3s have the distinctive twin round headlights that became iconic on the Speed Triple in the mid ’90s. These are LEDs with daytime running lights.
Both Rocket 3 models feature sculpted rider and passenger saddles, and an accessory in-fill pad makes it easy to switch between two-up and solo seating configurations. Seat height for the rider is 30.4 inches on the Rocket 3 R. At 29.5 inches, it’s even lower on the Rocket 3 GT, which comes standard with a brushed aluminum passenger backrest. As a roadster, the Rocket 3 R has midmount foot controls with two vertical position settings (0 inch / -0.59 inch). The touring-oriented Rocket 3 GT has feet-forward foot controls with three horizontal positions (-0.98 inch / 0 inch / +0.98 inch), and the passenger backrest is also height adjustable.
Triumph Rocket 3 GT with luggage
For the long haul, both Rocket 3 models can be accessorized with soft saddlebags, a tank bag and/or a tail bag.
A wide range of accessories are available for both models, including heated grips (standard on the GT, optional on the R), a quickshifter, GoPro integration, turn-by-turn navigation via the My Triumph app, Bluetooth connectivity, tire-pressuring monitoring, luggage (soft saddlebags, tank bag and tail bag), a sport windscreen and various handlebar and seat accessories.
The 2019 Triumph Rocket 3 R will be available in Korosi Red (shown) or Phantom Black, and the Rocket 3 GT will be available in Two-tone Silver Ice and Storm Grey with Korosi Red pinstripe decal (shown) or Phantom Black. Pricing and availability will be announced at the Rocket 3 press launch, which is scheduled for November.
well its far better looking than the original .
I sure would like to ride one!!!
I love it, much more than I was a expecting. cant wait to see one in the flesh
They did a good job or relieving a lot of that engine's ugliness. Looks far far better in thier version, tho still not and never will be the looked of any of the twin engines. But the bike's design removes some of the other ugly parts of the old ones like the tank. The left side is still a bit ugly which i guess they realize because 95% of the pics show it from the right side. I think they did a great job on these tho. Compard to the old ones they are a vast improvement looks wise.
Kinda hard to make that large an engine aesthetically pleasing on a bike. Think you forget about the looks when you exercise your right wrist.:)
Definately, but considering how ugly that engine is they did a heck of a job covering it up and taking attention away from it. I rode a R3 years ago when the power was lower and it weighed about 100 Lbs less then the new GT. Given how crazy powerful it was i can imagine what these are like at 100 Lbs less and a huge power and torque boost.
