tayamaj
- Local time
- Yesterday, 20:24
- Nov 14, 2020
- 12
- Points
- 5
- Age
- 55
- Location
- Columbus, OH
- First Name
- Jeff
- 2020 Bonneville Bobber Ironstone
Has anyone added extra LED either strip or other small LED light tapped in to the brake/run light to light up the back more? Did that make sense? The Bobber only has the one brake/run light, so I want the brake/run to be brighter, which is why I am wanting to add an LED strip lights or something by tapping into the bike's brake/run wires. If some of you have done it, first, would I need a fuse if I'm just tapping to the run/brake wires? Also, what color is the brake and the run wire? My thoughts were to do it this way, so feel free to correct me:
LED strip that I have has a wire for the brake light, wire for the running light, and two other wires for left & right turn signal (which I am not going to use).
So, I would tap the brake light wire to the bike's Yellow wire, which in my service manual says it's the brake/tail light. Question for me is, if i have two separate wires on the led strip for run and for brake, do i just tap both those wires into the bike's yellow wire? Obviously ground wire goes to ground.
Hope I made sense as I am doing two things at once, lol!
Thanks!
Thanks!
