Gerryk
- Local time
- Yesterday, 19:47
- Apr 2, 2022
- 52
- Points
- 17
- Age
- 44
- Location
- georgia
- First Name
- Gerry
- 1998 Triumph Trophy 900
Background…’98 Trophy 900 with 57k miles (40k by me). Shamefully not a lot of maintenance done, besides regular oil changes a few carb tune ups, valve adjustments, and spark plugs. My mechanical demeanor is willing to attempt pretty much anything but I’m not experience/qualified to identify subtle problems. If it’s obviously broke/worn, I have a chance. Otherwise I’m a forum/YouTube lurker. And I have a Haynes manual.
Problem…motor noise on deceleration. I would describe it as chain jingling/rattling. I’ve removed the alternator. There was a little bit of play in the center so replaced the bolt and center. Did not fix the problem.
Next…I’m thinking it’s time to replace the cam chain and tensioner. I’ve removed the crank cover, and honestly I would say the cam chain and guides look good (to an uninformed novice). Part of me thinks it can’t be bad to replace the cam chain at 57k, regardless of its condition. Thoughts?
If I go through this whole cam chain business and it ends up not being the problem, I guess I would head for the sprag clutch. If you were in my position, would you do the sprag clutch too while it’s all apart? It seems like a whole other invasive project. Advice?
I appreciate any advice/encouragement
