- Local time
- Today, 06:48
- Sep 1, 2023
- 538
- Points
- 127
- Age
- 64
- Location
- Albuquerque, NM
- First Name
- Joel
- 1971 Triumph Bonneville T120R
- Riding Since
- 1974
Paul Henshaw put up a video of a test ride on an OIF BSA (apparently with the same frame, forks, and hubs as my '71 OIF Bonny) that had a 750cc conversion on it. He noted it had a 21-tooth front sprocket added, and it's rpms at speed (disregarding the tach which he said reads almost 1K too high) seemed closer to what I'd like for highway cruising. The NM highways I'd like to explore typically have 70 mph limits (or lower).
I realize the tranny sprocket clearance may not be the same on the BSA as with my Unit 650 Triump, but would like to know if whenever I do the 750cc conversion to my bike whether I can fit a 21-tooth front sprocket as well? I'm running what I believe is the standard 46-tooth rear ring.
Thanks as usual.
Thanks as usual.
