Fitting Translogic Quickshifter to Thruxton R - positive coil Terminal?
BMac60
Riding for 49 Years
Today, 20:38
May 17, 2020
15
61
Newcastle, Australia
Brian
Thruxton 1200 R
BMac60
I am in the process of fitting a Translogic Quickshifter to my Thruxton R. The kit does not plug in to the factory quickshifter harness plug under the left side cover. (?)
Instead I have a harness with connections that intercept the positive wires into the coils (located on the frame under the fuel tank).
But what I need to know is which of the blade terminals on the coils is positive. The ( open - backed )left side connection fig1. or the right side (closed backed) connection fig1. ?
can anyone help?
i know that a multimeter will show which wire has a + 12 v current if I switch the key on, but I would imagine that with the tank off, I would need to pull the fuel pump relay or fuse so as not to have a triumph BBQ.
I am also thinking I might get a fault light / code issue.
i will attach the diagram of the coil and terminals from the service manual ( RHS) and a pic of my Coil (LHS)
BMac60
Riding for 49 Years
Today, 20:38
May 17, 2020
15
61
Brian
Thruxton 1200 R
All sorted now. BTW the terminal on the left was the positive. (Checked with multimeter) Wuickshifter fitted, adjusted and working smoothly.
CarlS
Charter Member #3
Riding for 62 Years
Today, 06:38
28,756
1,218
76
Altamonte Springs, Florida
Carl
12 Tiger 800 XC
Very good. TUP Thanks for reporting back.
wolfyvt
Riding for 8 Years
Today, 06:38
Feb 12, 2021
40
South Carolina
Triumph Thruxton R
Out of curiosity, were the instructions just trying to provide a +12V keyed-on access? I bought some heated grips that are looking for that and am trying to locate a terminal of wire. Thanks for any feedback!
BMac60
Riding for 49 Years
Today, 20:38
May 17, 2020
15
61
Brian
Thruxton 1200 R
Wolfyvt,
I needed to connect a circuit to the coils to interrupt the firing pulses during gear shifts. Not really what you need. A bit of poking around with a good test light should find you what you’re after, I would think.
Regards,
BMac60
wolfyvt
Riding for 8 Years
Today, 06:38
Feb 12, 2021
40
South Carolina
Triumph Thruxton R
Wolfyvt,
Regards,
BMac60
That makes complete sense. Thanks for the quick reply!
