Fuel Issue
brokeback
Riding for 7 Years
Today, 11:11
Dec 6, 2016
14
36
usa
ryan
tiger 955
Im having random fuel delivery failure while riding. It last for less than a second and the onset is very random. When it cuts out the fuel light and check engine light come on for about 3 seconds. It happens at random RPM and throttle. Over the last year I have replaced spark plugs, voltage regulator, stator. I did not notice any issues after everything was installed but then about 2 months later it started. I have tried a new fuel pump and ran fuel treatment to try and clean the fuel system with no success. Any ideas?
shanered6
Time for adventure
Riding for 43 Years
Today, 16:11
Apr 5, 2011
5,869
435
50
Turriff, Aberdeenshire
shane llywarch
2005 sprint st 1050
It could be the fuel couplers the valves in side get worn and they do leak as well some times which means they suck air .... just a thought !
Chuck
Tomorrow, 01:11
Mar 23, 2015
Australia
Chuck
Tiger 800XC 2012
If the fuel pump relay and/or wiring circuit has an intermittent fault this could happen. The fuel pump is briefly without supply voltage. Or, if the ECU signal to control
the fuel pump is intermittent.
triumph david
Riding for 59 Years
Today, 10:11
Nov 25, 2013
4,761
273
71
brookhaven
david
Check all of the ground connections you can locate especially the wiring connections around fuel pump relay, fuel pump,ect. Good luck.
keystiger
The Joker
Riding for 39 Years
Today, 10:11
Mar 24, 2009
6,629
439
50
The SWAMP
Adrian
2005 Triumph Tiger, British Racing Green--the fastest color
Perhaps the vacuum hoses around the intakes???
My girls ran like CRAP after setting up for a few months-- hard to start once started wouldnt STAY running misfiring -- I tried several things till I was fiddling around with the tank off and noticed one of the MANY little vacuum tubes at the rear of the three intakes (there are a BUNCH of them) had dry rotted at the connection --- then I moved it and one of the others damn near disintegrated in my hand-------its a wonder the thing ran at all the week before!!!!!!!!!!!!
turned out a couple hours of doing contortions with my fingers -- 2 Aleve---and some fresh rubber from the auto parts store and BANG ON runs like a new bike!
triumph david
Riding for 59 Years
Today, 10:11
Nov 25, 2013
4,761
273
71
brookhaven
david
Most of the times its something simple just like those vacuum lines!
  • Like
Reactions: keystiger
