Fuel leak problem
rodsridin
Riding for 62 Years
Yesterday, 18:32
Aug 24, 2018
17
Wa.
Rod
2007 Scrambler
Turn the fuel petcock on my 2007 carb Scrambler and noticed leaks coming from both carbs. Pulled them off and found the fuel distribution manifold tube leaking on both ends. None of the carb diagrams available to me show any parts and seals for this but I assume it's just o-rings. The tube has slight end play and is free to rotate. All my research says to never pull the carbs apart but that's the only way I'm going to get to the problem. Any experience out there accessing this part would be helpful.
Thanks for any comments - Rod
Rocky
Still Rocking
Riding for 28 Years
Yesterday, 20:32
Jan 28, 2006
18,240
893
82
Halifax
Rocky
2006 T100 Bonneville
Sorry, the carbs on my '06 Bonneville have never had a problem or off the bike so I'm of no help.
rodsridin
Riding for 62 Years
Yesterday, 18:32
Aug 24, 2018
17
Wa.
Rod
2007 Scrambler
Thanks gumpt1oo. Looks like the right call on the schematic. So far no problems getting down to the part. Hopefully it will go back together as easily. Triumph dealer here wanted to replace both carbs. That's why I don't take my bikes to dealers who specialize in replacing rather than repair.
rodsridin
Riding for 62 Years
Yesterday, 18:32
Aug 24, 2018
17
Wa.
Rod
2007 Scrambler
Follow up on this post: The o-rings shown on the schematic are for the vent-T not the Fuel Swivel T. I need to replace the vent rings anyway since I disassembled the joined carbs and don't want to re-use cheap o-rings. So, it's off to the auto parts store to find suitable rings for the fuel T. I have measured the ring seats so just need to match for an interference fit in the carb bodies. In the meantime, I will be headed out to California wine country so won't have the Triumph back together for week.
rodsridin
Riding for 62 Years
Yesterday, 18:32
Aug 24, 2018
17
Wa.
Rod
2007 Scrambler
Final follow up: All back together and it fired up no problem. A little adjusting to both carbs and it is running smoothly.
As a side note, I have read one thread here about removing the carb heaters to make adjusting the air screws ready available. Yes, you can remove them and plug off the holes with a m8x1.25 plug and removing the wires for neatness. I did not remove them but simply loosened the heaters and then rotated the flat tab ground connector out of the way and re-tightened the heater. Now the air screw is clear to easily adjust. The ground tab is just a washer for the heater. I'll try to attach a photo here that shows both carbs with the wires still not attached. You can see the airscrew pockets are in the open.CarbHeater1.jpgCarbHeater1.jpg
Rocky
Still Rocking
Riding for 28 Years
Yesterday, 20:32
Jan 28, 2006
18,240
893
82
Halifax
Rocky
Thanks for the follow-up report.
Nice to hear that it was a relatively simple fix TUP
triumph david
Riding for 60 Years
Yesterday, 18:32
Nov 25, 2013
5,437
355
72
brookhaven
david
Marko65
Riding for 36 Years
Today, 02:32
Mar 26, 2020
1
55
Finland
Marko
Bonneville 2005
Hello, do you have size for o-rings from auto store parts.
BR
-Marko-
