- Local time
- Yesterday, 20:06
- May 25, 2019
- 3,967
- Points
- 577
- Age
- 64
- Location
- Houston
- 2005 Triumph Thruxton 900
- Riding Since
- 2019 licensed about a decade earlier.
This weekend I’ve been looking over the 2005 Thruxton and starting it up a few times. Also put a fan in front so I could run it safely to warm up. So at one point the engine sound changed and after a bit it stalled. Tried restarting and it failed to start. I had earlier put a gallon plus into the tank. I suspected it may have traveled with little gas. The oil was certainly low and I added some as well. Several quarts at least. So I concluded it was essentially shipped dry. Now to my question. The fuel petcock was pointing to the front when it ran out. When I turned it 90 degrees to point up it restarted. My understanding is that normally it should point to the rear of the bike to full. It only turns between the front and 90 degrees to up. How do I get it pointed to full to the rear position?
