Gear Change Woes
Twin Pots
Riding for 57 Years
Today, 19:28
Nov 7, 2018
128
27
61
Calamvale
Triumph Bonneville 1967
FJR 1300 Yamaha
I did promise sometime ago to provide an update on a gear change issue I was having. It began with losing first gear on my 67 Bonneville. No amount of prodding pushing or pulling would engage first gear. Praying to the shrine of Saint Turner that it wasn't a fault inside the inner workings I pulled off the outer gearbox cover. My prayers were answered as it transpired to simply be one of the two quadrant springs that had broken. Easily and cheaply replaced first gear was once more easily selected. Then the dreaded BUT, I immediately discovered fourth gear had become somewhat shy. It took two or even three goes to engage fourth gear every gear change! I was 99.9% convinced it wasn't a coincidence and was somehow connected to the previous problem. I also decided to live with it for awhile but a painful right toe eventually led to a second peek inside Turners wonderful world of cogs. As a matter of course I replaced all the bearings accessible in just the outer cover including seals although they were fine. A long hard look at the new springs revealed two points. The new springs are a fair bit shorter than the originals plus the quadrant thingy was not entirely centralised when at rest. I concluded that this lack of being in the exact middle position (it wasn't by very much at all) might be enough to limit the amount of travel required to engage fourth gear. I inserted a couple of washers at one end of the spring to centralise the quadrant thingy and voila! on assembly I now had fourth gear with just a snick of the gear lever and a toe that is much happier. Although the new springs were shorter I don't believe this was a problem, it was simply the imbalance between them. Packing one with washers was the cure.
Rocky
Still Rocking
Riding for 28 Years
Today, 15:28
Jan 28, 2006
18,873
893
82
Halifax
Rocky
2006 T100 Bonneville
It's always nice to read good news TUP TUP
CarlS
Charter Member #3
Riding for 62 Years
Today, 14:28
28,474
1,218
76
Altamonte Springs, Florida
Carl
12 Tiger 800 XC
Excellent! Glad you solved the problem. Thank you for reporting back.
grandpaul
Old Bike Lover
Riding for 51 Years
Today, 13:28
Apr 14, 2006
3,180
272
63
Leander, Texas
2000 Legend 900 Triple, 2002 Bonneville
I hope those washers can't find their way loose...
