Help Needed With Some Info Please
Gandolf
New Member
Riding for 45 Years
Today, 03:11
May 29, 2021
60
Derby
steve
1960 Bonneville T120
Hi guys, my mate has a t120 Bonneville, he has dyslexia which is why i am here on his behalf, the right hand side exhaust is hot and the left hand side is tepid, he has a 1960 120. things i have done, compression test one kick 25ppf, 4 kicks 75ppf on both cylinders, ive swapped the carbs over, and the coils nothing makes any difference, ive set the tappets cold to 2tho inlet and 4thou exhaust, has any one heard of a this ,or know any reason why this would be happening. cheers steve
Greyfell
Proud Nerd
Riding for 4 Years
Yesterday, 19:11
May 4, 2016
2,790
292
64
Northern California
Stephen
Initially, I might have said the two cylinders are burning unequally, but you don't mention a loss of power or straining to maintain speed. Therefore, the thought comes to mind that the left-hand side exhaust has a partial blockage, forcing most of the exhaust out the right-hand side.
I might be wrong; I don't have many years of experience, but this does explain the difference, logically.
Gandolf
New Member
Riding for 45 Years
Today, 03:11
May 29, 2021
60
Derby
steve
its one exhaust per cylinder, no connecting pipe, i stood at the rear with a hand in front of each pipe, and the rhs has warm gasses and the lhs cool, the lhs one does get hot eventually but no where near the rhs one, which was the reason for swapping the carbs over and then the coils, when i adjust the air screw on the lhs all though it makes it run a little rough it still keeps going, but if i do it on the rhs it stalls, both the air screw are set to one and a half turns out, and i only adjust very slightly, the same thing occurs when the carbs are swapped over, it has electronic ignition fitted, when testing for a spark manually both are strong, ive tried the plugs in both sides and that makes no difference, i have personally not ridden it, but my friend said he noticed no loss of power the factor to check was the colour of the pipes. rhs clear blue for around 6 inches down from port, left hand side is still chrome colour. it has me puzeled.
Gandolf
New Member
Riding for 45 Years
Today, 03:11
May 29, 2021
60
Derby
steve
i will swap ht leads over today as i forgot to do that yesterday, i am also going to check fuel flow from each tap, and drop a timing light on the ht leads while it is running, other than that i am at a loss.
Qship
Riding for 40 Years
Yesterday, 23:11
Feb 25, 2014
4,362
478
Steve
'17 Tiger Explorer XRT
This forum is for the newer T120s. May get viewed by someone with more experience on the older T120s posting in the classics section.
Rocky
Still Rocking
Riding for 29 Years
Yesterday, 23:11
Jan 28, 2006
19,409
893
83
Halifax
Rocky
2006 T100 Bonneville
There are a couple of very knowledgeable members monitoring the classics section.
That's where you should direct your questions about the Meriden T120's.
Gandolf
New Member
Riding for 45 Years
Today, 03:11
May 29, 2021
60
Derby
steve
Think ive sussed it any way, timig light not flashing on lhs, pointing towards electronic ignition box, but yeh will look for the classic section.
Greyfell
Proud Nerd
Riding for 4 Years
Yesterday, 19:11
May 4, 2016
2,790
292
64
Northern California
Stephen
Sounds like you're well on your way to finding the source of the problem. Posting your question in the recommended section will get you verification.
Gandolf
New Member
Riding for 45 Years
Today, 03:11
May 29, 2021
60
Derby
steve
I have found the problem, First question i asked my friend was are the plugs new, his reply was yes. i should have tested them under load, i replaced the lhs plug and got an improvement, so that led me to raise the slide on the lhs, slowly i could hear the engine pick up , so i removed the carb and stripped it down, both side plug where wet, so i removed all the jets and internals and cleaned with carb cleaner, i also lowered the needle both sides by one notch, This improved its running , after i adjusted the mixture screws on both carbs its like new again, both pipes getting hot equally. Initially i thought that the mk3 box was at fault, but because it ran on one that could not have been the case as it contains a switching diode so moral of the story is check the basics first, despite what your told. Thanks for all your help.
Rocky
Still Rocking
Riding for 29 Years
Yesterday, 23:11
Jan 28, 2006
19,409
893
83
Halifax
Rocky
Greyfell
Proud Nerd
Riding for 4 Years
Yesterday, 19:11
May 4, 2016
2,790
292
64
Northern California
Stephen
Good work. Sehr Schön, Gandalf.
triumph david
Riding for 61 Years
Yesterday, 21:11
Nov 25, 2013
6,034
443
73
brookhaven
david
Glad you found the problem, alot of times its something simple.
