Ignition problem
Motorcar
New Member
Riding for 40 Years
Today, 13:31
Jul 22, 2020
6
46
Utah
Edwin
Bonneville T100
It all started when I noticed that the low beam wasn,t working. Replaced the bulb now it turns on sporadically. High beam works fine, however, I was riding one time and I lost all lights at night, and quickly they turned on. The new problem. Bike starts fine, I start riding and the motorcycle stalls after a while, try to start with no success. It will finally starts again after 20 minutes later or so. Fuel tank full, oil within limits. I need some advise. Thank you beforehand.
CarlS
Charter Member #3
Riding for 62 Years
Today, 15:31
27,997
1,163
76
Altamonte Springs, Florida
Carl
12 Tiger 800 XC
The lighting problem sounds like a bad or loose connection or a bad ground.
The new problem is somewhat similar to a problem I had with my 2003 T100. That turned out to be a bad coil.
Motorcar
New Member
Riding for 40 Years
Today, 13:31
Jul 22, 2020
6
46
Utah
Edwin
Bonneville T100
Thank you for the info. I will check the coil.
Darren.clark
Today, 15:31
Jul 23, 2020
36
Tampa, Fl
Darren
2007 Bonneville black carb
this isn’t happening directly after you wash the bike, right?
sikatri
Today, 14:31
May 25, 2019
358
57
60
Houston
2005 Triumph Thruxton 900
Following. I’d suspect the coil as well for the new issue. It’s sounds similar to an issue I’m having. I have a new coil on the way.
Trevor
Today, 20:31
Sep 6, 2014
13
67
Trevor Jones
2001 Bonneville
Could be the timing sensor causing the ignition problem. The sensor on my Bonneville was faulty- bike goes fine- bike stops- wait for 15 minutes- bike goes fine until bike stops etc. Easy job to replace. It is under the right hand side cover over the alternator and it is set with a feeler gauge. The hard part it figuring out the where the connecting wires are routed.
ccrossi@verizon
Riding for 56 Years
Today, 15:31
Jul 26, 2020
1
73
Aliquippa
Clarence
1966 TR6C
Reading this reminded me of the same issue I had with my 1966 TR6C. I went out one night for a long ride. On my way home I had to climb a rather steep hill. Half way up that hill the bike stalled. I could not start it again. I reasoned I might have been out of gas. I opened the tank and looked into the tank and saw I had plenty of gas. After a few minutes i was able to start it again. I had it stall on me several times after that. Each time I looked to see if I had enough gas. After a few minutes I was always able to start it again.
One day I was studying the gas cap and found the vent hole plugged. I cleared the obstruction and it never happened again. It may sound elementary but its the little things that drive us crazy. I think that as the gas drained out of the tank a vacuum occurred keeping the fuel from draining into the carburetor.
Greyfell
Proud Nerd
Riding for 3 Years
Today, 12:31
May 4, 2016
2,270
217
63
Northern California
Stephen
So often we overlook the easy fixes.
Motorcar
New Member
Riding for 40 Years
Today, 13:31
Jul 22, 2020
6
46
Utah
Edwin
Bonneville T100
Let us know what you find.
Updating my ignition problem:
Ive ordered the maint book. and Started troubleshooting the Ignition coil along with the Camshaft position sensor. I measured the coil prior to starting the bike and it measured 0.6 ohm, this is within tolerance according to the book. Also, I measured the camshaft Position sensor, which showed some sort of measurement, however, the book doesn't show tolerance for it. I ran the motorcycle to make it stall, and I retook both measurements, and these are the results; The camshaft Position sensor gave some sort of reading, while the Ignition coil showed no reading whatsoever. I'm under the impression that somehow when the coil gets to a certain temperature, it stops working and then when it cools off, it works again, as when it's cool I got the 0.6 ohm again. Unless there is some sort of protection system, that turns the ignition coil to prevent engine damage, I believe I have a faulty ignition coil. I ordered one, I will keep you posted. Ive heard this is a common problem in the T100. However, if it is, is very annoying and the coil is about 160 dollars tax included.
Motorcar
New Member
Riding for 40 Years
Today, 13:31
Jul 22, 2020
6
46
Utah
Edwin
Bonneville T100
Let me know, If your ignition coil was at fault, I ordered one as well.
