Magno
- Local time
- Today, 06:17
- Jul 6, 2013
- 67
- Points
- 7
- Location
- London
- First Name
- Magno
- Triumph T140V
Dear Bikers
In order to make clutch action a bit easier I have recently changed my T140v Bonneville to a 7 plate clutch and softer springs. Although this appears to have worked well I now find problems with clutch adjustment.
I have set the 3 clutch springs to open correctly and have relied on the pushrod and cable adjustments to get the correct clearance.
The problem is that I can't get it correctly set to easily attain neutral gear. It changes into neutral quite easily when the bike is moving but whilst staionary it is extremely difficult. All other gears are easy to locate.
I've tried all possible adjustments of the cable but to no avail.
If you have any advice I'd be grateful.
Best wishes
Magno
Best wishes
Magno
