Walmart's Supertech filter is made by Champion and is one of the highest rated filters on the market. ST6607 is the standard filter and ST7317 is a bit longer with more capacity.
Bosch 3323 or 3300
NAPA Gold 1356
Purolator L14610 or L14612
Purolator Pure One ML16819
Motorcraft FL 821
All are 20x1.5mm threads, 2.3" gasket diameter with a bypass valve of 8 to 14 psi and anti drain back valves.
Good stuff Carl
Just for laughs I compared the OEM oil filters for my Honda CB900F (919 or Hornet) and Triumph T100. They are identical with the same english and Japanese (oriental ?) writing.
Both say "Filtech Inc - assembled in the USA"
Only the names have been changed to protect the guilty
A little extra research, I have no actual experience with any other than the SuperTech ST6607 , the longer ST7317 and the Purolator L14612. If you should decide to use one of these listed below, be sure and do a little research of your on prior to use. I found the information on Oil Filter Cross Reference at http://www.oilfilter-crossreference.com/ For the stock length filter
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
