Paddock Stand For Triumph America
Quickie
Riding for 1 Year
Today, 03:56
Feb 11, 2021
3
54
Wyboston, Bedfordshire UK
Ian
Triumph America
Hi everyone, I’m looking for a paddock stand to fit my Triumph America and I don’t seam to be having a lot for joy. Can anyone give me or tell me what to go for.
Cheers Quickie
Jackal
Riding for 3 Years
Yesterday, 22:56
Apr 11, 2020
37
28
North Carolina
Alex Norris
2009 Speed master
Cheers Quickie
Here is one at New Bonneville out of Texas.
Jackal
Riding for 3 Years
Yesterday, 22:56
Apr 11, 2020
37
28
North Carolina
Alex Norris
2009 Speed master
Cheers Quickie
This is one from custom cruisers in the UK they have pretty good customer service if you have issues with the product.
Hurtle
Riding for 44 Years
Today, 12:56
Mar 1, 2020
57
17
62
Camperdown
Peter
2011 America (aka Roy)
FWIW - I haven't gone the permanent centre stand route because I'll only need it for servicing (oil/filter change, chain maintenance). So, I made one out of scrap steel for a $0/1 hour investment. Only new part was 300mm of 10mm threaded rod for a mounting point on the bike. Saves unnecessary excess running weight, too. Please pardon the crappy welding. Design available on request. (Mind you, I'm re-designing at the moment to make it less "agricultural".)
Moss
Today, 03:56
Jan 30, 2017
11
69
Moray
Triumph America
Hi Quickie,
I use a rolling hydraulic jack under the frame but in earlier days I used a wooden block screwed to a 4ft wooden lever bar to jack the rear wheel off the ground. Its cheap, its a one man job and it works every time.
Mvander
New Member
Riding for 38 Years
Today, 12:56
Jun 9, 2021
8
57
Melbourne
Mark
07 Speedmaster
Mvander
New Member
Riding for 38 Years
Today, 12:56
Jun 9, 2021
8
57
Melbourne
Mark
07 Speedmaster
How does the stand sit under the bike. B keen to see some underneath photos
Hurtle
Riding for 44 Years
Today, 12:56
Mar 1, 2020
57
17
62
Camperdown
Peter
The America’s has lugs at look like they’re designed for fitting a centre stand. I used a length of threaded 10mm (3/8 inch) rod with washers and nylock nuts on each end. It’s just visible in the photo taken from the right hand side looking down. (20200409_162826-jpg.49223/)
Below the bend in the brake line.
Hurtle
Riding for 44 Years
Today, 12:56
Mar 1, 2020
57
17
62
Camperdown
Peter
Might be easier to see in this shot.
sikatri
Yesterday, 21:56
May 25, 2019
644
77
61
Houston
2005 Triumph Thruxton 900
Dunstall makes a similar one, I bought one for my Thruxton. Yours works so you saved a bunch of money. LoL.0F729937-B5FC-4A36-A41A-E845A19C930A.jpeg4EB948C1-DDD6-427E-B81F-D402F9C44EE2.jpeg3C9BC9CF-F156-4EFD-A8B1-23E0ED5E8026.jpeg
sikatri
Yesterday, 21:56
May 25, 2019
644
77
61
Houston
Any chance of getting some dimensions for this stand?
I can measure mine today. I’ll do a hand drawn sketch with dimensions. I’ll post it by this evening.
Hurtle
Riding for 44 Years
Today, 12:56
Mar 1, 2020
57
17
62
Camperdown
Peter
Told you the welding was ordinary! Dimensions from memory. I have my design drawings somewhere and will post exact measurements when I find them!
Base is a piece of 4" pipe - 500mm long. Uprights 1" square - 210mm. Lifting lever (fixed) also 1" square - 400mm. Crossbar is 13mm (1/2") pipe with a 10mm (3/8") groove cut along its length, which is also 210mm - the groove is at the top of the stand. You need to have a free/floating release bar to enable you to slip it under the bike from the left hand side and engage the 3/8" rod I mentioned earlier into the groove and avoid it slipping out. The "release latch" is simply a piece of 2"x2" angle welded to the end of the base on the opposite side to the lifting lever at the correct angle. A couple of strategically placed 2"x1" chain links stop the release lever (an old wheel nut wrench with the socket removed) from slipping while lowering the bike but will allow it to detach once it's done its job. All foot operated and works like a charm, despite its looks.
Hurtle
Riding for 44 Years
Today, 12:56
Mar 1, 2020
57
17
62
Camperdown
Peter
BTW - where are you, Mvander? I'm SW Vic.
Hurtle
Riding for 44 Years
Today, 12:56
Mar 1, 2020
57
17
62
Camperdown
Peter
Couldn’t find my design drawings, so measured it.
Base pipe - 3” dia, 24” long
Uprights - 1” sq, 6” long
Crosspipe - 1/2” pipe 7 1/4” (185mm) long with 3/8” (10mm) slot cut full length on the top side.
Raising lever/Standing rest - 1” sq, 12” long at approx 12.5 deg offset from Uprights
Lowering lever is any piece of rod that you can find - it is removable.
Lowering latch is 2”x2” angle at approx 15 deg opposite to raising lever, with one chain link to anchor the lowering lever and another beside it to stop it from slipping off when lowering. I reckon you could use 2”x1” steel - with a plate welded on the end that has an appropriately sized hole (slightly larger dia than your release lever).
I used 3/8” threaded rod between the lugs on the frame that look to be there for fitment of a centre stand and used nylock nuts to secure it. You could use a bolt at each end extending an inch or two in from the outside.
I saw this as a challenge to design and make something that I needed, rather than go out and buy something (tried that!) that didn’t fit. Success is so satisfying - even though it’s ugly as sin.
