Chriss217
- Local time
- Today, 20:30
- Apr 16, 2021
- 3
- Points
- 2
- Age
- 72
- Location
- UK
- Triumph Trophy 1200 '98
The rear brake hose is secured to the swinging arm via a clip screwed to the arm with torx screws. Between the hose and clip is a rubber bushing,
Unfortunately it seems that I cannot undo the torx screws to release the clip and hence remove the hose.
Has anyone found a way to extract the hose without taking the clip off?
Obviously I can cut the hose and pull the old/worn hose out from either side, however I need to install a new hose that has connectors at both ends.
Best. Take care out there.
