nickjaxe
- Local time
- Today, 14:26
- Dec 30, 2020
- 202
- Points
- 27
- Age
- 71
- Location
- England.
- First Name
- Nick
- 2020 T100 Bonnie.
Sorry.....no idea how many are effected and if its caused failures.....Triumph say I am the only person to contact them.....I know at lest 4 who have.So to help with the anxiety which I do understand. I asked a few questions, like how many engine failures has this particular engine and Triumph model had and how many were determined to be related to a ticking noise prior to warm up? If there’s no definitive numbers and cases or exceedingly relative to numbers produced and engine failure cannot be determined to be related to the ticking sound or is explained by other failure then you’re just going to stress more. I’m not saying you can’t take your whole motorcycle apart, but don’t be surprised if no matter what you do the noise always appears and disappears as it warms up. Some people stress and report these noises, but it’s likely a larger number know it’s exists and accepts it as an engine warming up and keep riding. You can spend your time thinking about the noise or thinking about your next ride and where you want to go. Good luck no matter what you choose to do, but I fear you’re creating an obsession for yourself. I’ve been down this road in 2008 and 2009 listening and discussing the noise our MINIs made prior to warm up. I still have my MINI and the engine still ticks and makes noises prior to warning up. I’ve replaced parts as needed and added about 50 HP and nothing has changed. So look at cases of failure and see if the numbers justify a lot of money in investigating this issue. If this is an issue there will be data to support it.
But of course Triumph would say that,
I am a mechanical person.....a noise in a engine should never be ignored.
Once I start the bike and let it warm and then ride off....I forget about it till the next cold start......there are many more like me are worrying about the watercooled Bonnie motors making this noise....its not just me.
