- Local time
- Yesterday, 22:24
- Sep 1, 2023
- 538
- Points
- 127
- Age
- 64
- Location
- Albuquerque, NM
- First Name
- Joel
- 1971 Triumph Bonneville T120R
- Riding Since
- 1974
Okay, well I had an expectedly quiet afternoon, so got after it!
The skinny O-rings clearly weren't doing the job, and I had an awful time with the fat ones, which kept flopping around and shifting out of place. So, I did what a guy on 'that other forum' said he's been doing for many years: just used flat gaskets with a bit of sealant on them.
Voila. Engine stopped racing and--although the tachometer may be reading a little high--I got her settled down to what sounded like a reasonable idle before it started to get too dark to have the garage door open (mice will dash past you and cause sleepless nights).
I'd like to do the strobe timing to eliminate that from the equation re: any misses I might detect, then see if I can get the idle and low speed mixture acceptable for whenever I get the kickstand repaired and can do some road testing of the slide cutaway and needle setting. Hard to do a load test for a good mixture reading of the plugs if it's on the stand...
