H0rus
- Local time
- Today, 22:05
- Mar 26, 2016
- 3
- Points
- 0
- Location
- London
- Speed Triple
Coming home from a very long ride noticed it was hard to downshift from 5th until I was stuck in the gear. That happened some 20miles from home which is good. To get the bike out of gear I need to turn it off and slowly move back and forth until I found neutral. I avoided to get from 4th onwards but last miles to home noticed that 4th was also problematic but not always. At the first light problem was also finding neutral. Problem appears only when downshifting. 2 years ago I also took off the gear linkage and replaced with a small shift lever. Next thing that I've done is new clutch cable, slack adjusted by manual. That didn't solve the problem. Oil was changed 500miles ago with the same that I'm always using, level is fine. Took the clutch cover off and started inspecting things. What I noticed so far is,
Took the outer drum out too and started inspecting things but can't see anything wrong. Any idea what might be from the pictures and videos? Thanks
VIDEOS
YouTube
- Outer clutch metal plates are slightly colored purple, friction plates measured and are all like new inner and outermost 3.80mm and others 3.30mm.
- Outer drum seems to have a lot of play
VIDEOS
YouTube
