Throttle Body Bal Help
dscshooter
Today, 03:05
Jul 20, 2016
4
45
USA, Kentucky
Dennis
2015 Speed Triple
image.png Ive noticed some rough idling and hooked up dealertool to view throttle body readings. Numbers 1 and 3 were balanced together but 2 was way off; 67-58-67. Removed the airbox and went to work. The best i could get is 65-57-65. I had the center adjuster nearly screwed all the way in. I experimented with many different ways to try to get them in synch. I checked all of the map hoses including the two going to cylinder 2 and they were all good. I then viewed the sensor readings with dealertool and attached those screenshots. Im curious about the fuel injectors. Looks like number 2 reads much lower. Any thoughts? 2015 Speed Triple
dscshooter
Today, 03:05
Jul 20, 2016
4
45
USA, Kentucky
Dennis
2015 Speed Triple
Its fixed!!! Sai hose was pushing up on map vac line to cyl 3. If you have a newer speed, id check this and push down on the sai hose and see if your kpa or mmhg changes.
Rocky
Still Rocking
Riding for 30 Years
Today, 04:05
Jan 28, 2006
20,417
952
84
Halifax
Rocky
2006 T100 Bonneville
TUP Glad to hear it as I had not the faintest idea how to help you BGRIN
