Thruxton engine and transmission covers
sikatri
Today, 07:40
May 25, 2019
493
57
60
Houston
2005 Triumph Thruxton 900
My current passion is reading ads and trying to figure out what it means. What is the original finish? Polished aluminum? If you saw this in an add, what would you think?
Rocky
Still Rocking
Riding for 28 Years
Today, 09:40
Jan 28, 2006
18,699
893
82
Halifax
Rocky
2006 T100 Bonneville
It was probably clear-coated aluminum and the clear-coat began to flake off. (??)
sikatri
Today, 07:40
May 25, 2019
493
57
60
Houston
I wonder why one wouldn’t just redo a clear coat then? The photos look like aluminum at a distance. It looks original, wondering if he used a clear powder coating on them. It looks like an original from photo distance.
sikatri
Today, 07:40
May 25, 2019
493
57
60
Houston
Not a good picture, but an iPhone enlarged. The bike is pretty close to what I’m looking for. LoL. It has miles, but no obvious signs of neglect or abuse to me. The only thing that made me ask why, was the paint on the covers. Is finish wear and deterioration an issue with these parts due to age or use?
Rocky
Still Rocking
Riding for 28 Years
Today, 09:40
Jan 28, 2006
18,699
893
82
Halifax
Rocky
I don't think it is common at all, but my T100 has chrome covers so others with later non-chromed models will have to reply.
sikatri
Today, 07:40
May 25, 2019
493
57
60
Houston
I just googled “clear powder coat aluminum” and it appears to be one option for refinishing where a clear coat needs replacement. My ignorance, I had not thought that the aluminum parts had any protective coating. I always thought they were brushed aluminum or polished.
CarlS
Charter Member #3
Riding for 62 Years
Today, 08:40
28,311
1,218
76
Altamonte Springs, Florida
Carl
12 Tiger 800 XC
Aluminum can pit and corrode if not protected.
sikatri
Today, 07:40
May 25, 2019
493
57
60
Houston
How many original finishes were there for these parts? More than one? Been looking at Hermys parts lists. Brushed and lacquered, polished and misc others depending on part. I’m trying to get a feel for what may or may not be original. Since I’m mostly looking at pictures now for candidate bikes, I may make a snap decision on a bike and dismiss a possible candidate. I’ve noticed a few older links may need updating on the forum. Should I comment when I run across one?
Rocky
Still Rocking
Riding for 28 Years
Today, 09:40
Jan 28, 2006
18,699
893
82
Halifax
Rocky
I could be wrong, but I don't think anyone here would have all the information about the various finishes year-to-year.
Comment on any threads you like.
sikatri
Today, 07:40
May 25, 2019
493
57
60
Houston
I’m getting an idea there is some variation. That’s good to know, thanks.
sikatri
Today, 07:40
May 25, 2019
493
57
60
Houston
It makes me more comfortable looking at some bikes where I see variations that I was not aware of.
sikatri
Today, 07:40
May 25, 2019
493
57
60
Houston
The cover indeed has a clear cost of some type over aluminum. The damage is under the clear coat. It would appear it has failed in some spots. I don’t plan to re-coat with a clear coat at this time, but I will need a protective coating of some type.
sikatri
Today, 07:40
May 25, 2019
493
57
60
Houston
Here’s what is underneath the clear coat, a brushed aluminum finish. You can see the areas with clear coat still on. I’ll remove the clear coat by small amounts of acetone and then gently scrape it off. A finger nail is enough to remove it, I’m using a wood piece or wood bbq skewer. I don’t want to use a lot of acetone near the seals and rubber bit. Going to have to go slow. After I remove the coat I’ll clean up the remainder of the aluminum damage. It’s all pretty superficial. This is a bit of an experiment. The other covers have similar damage, but not as much or as visible. I’ll probably treat them later when I have reason to remove them from the motorcycle for maintenance reasons.9A953AFB-3D3A-45F4-AAC6-0AD1561BFDBA.jpeg
sikatri
Today, 07:40
May 25, 2019
493
57
60
Houston
So I removed the clear coat and cleaned it up a bit. Some fine brass wool and a sparing bit of 150 grit on a few of the roughest spots along with Mother’s aluminum polish, says it shines and protects. Thinking it might still need wax as well. Thoughts? Next going to remove the front sprocket cover and clean and lube the chain, plus clean the cover.2F3AB083-9A26-4889-B9BA-5DDB12064D08.jpeg
Rocky
Still Rocking
Riding for 28 Years
Today, 09:40
Jan 28, 2006
18,699
893
82
Halifax
Rocky
Allen B.
New Member
Riding for 44 Years
Today, 08:40
Sep 8, 2020
60
Ohio
Allen
2011 Bonneville T100
Good job, looks great
