Thunderbird 900 seat
dearborn
Today, 10:05
Sep 29, 2015
111
27
70
Dearborn Michigan USA
Doug
I have a '96 Thunderbird 900. The seat is awful! After 30 minutes, I'm squirming and my butt is sore. Looks like maybe the PO had short legs? and maybe cut down, kind of "scooped" the foam in the front part of the seat a bit. At any rate, the foam is 22 years old and worn out. Have a Corbin seat, foam is nicely stiff and fairly comfortable, but EWWW! That seat is ugly! Have an "Air Hawk" inflatable strap on pad that works, sorta, but like sitting on a hemorrhoid cushion and adds to seat height making for tippy toes at stops. Asked here elsewhere for suggestions = foam replacement, gel inserts, etc. Not a lot of response. No need to buy a new seat, mine in great condition, but want to make this one better. Any ideas out there?
Gogreen
Riding for 46 Years
Today, 15:05
Jul 2, 2015
40
UK
Phil
Thunderbird Sport; T140D
as a temporary relief, try a pair of cycling shorts under your jeans/leathers, old trick but cheap and effective
triumph david
Riding for 60 Years
Today, 09:05
Nov 25, 2013
5,202
355
72
brookhaven
david
My wife and i have some gell pads, they work but do add a little height in the saddle. The thing that brothers me is my age, you get older and get tired quick, i have a year or 2 on you so you probably are feeling like me.
dearborn
Today, 10:05
Sep 29, 2015
111
27
70
Doug
I'll be 70 in March, riding since 1965, R knee replacement in 2012, average maybe 3-5k miles per year on Triumph, Norton and Aprilia. Actually a little height in the seat, maybe 1/2 inch would be OK. 22 year old foam squashes right down with weight. Have an "AIRHAWK" inflatable pad that works OK for long rides, but not so good in town. Need some quite firm closed cell foam, like that used in those "plywood" Corbin seats. Keeeping an eye out for a cheap donor Corbin on EBay.
dearborn
Today, 10:05
Sep 29, 2015
111
27
70
Doug
GEE! Finding proper foam for seat is harder than I thought, hence my idea of using Corbin "plywood" foam from a donor seat
Qship
Smile, you're on camera. Somewhere.
Riding for 39 Years
Today, 11:05
Feb 25, 2014
3,239
302
Steve
'17 Tiger Explorer XRT
May be a auto upholstery shop? They would have different density foams for car seats. Should be able to shape one for your seat.
dearborn
Today, 10:05
Sep 29, 2015
111
27
70
Doug
Yes, but auto trim shops I've spoken to use a much softer foam, not firm enough for my purpose
JoDArk
Riding for 61 Years
Today, 09:05
Aug 17, 2018
32
75
Arkansas
2008 Triumph Thruxton Carb Model
This is late and you may have solved your problem, but I have heard that the rebond foam used under rugs make a good base for seats....glued in layers like plywood then cut to shape as needed and some use a piece of memory foam on top before the cover is replaced.
dearborn
Today, 10:05
Sep 29, 2015
111
27
70
Doug
I will definitely look into your suggestion, thanks! I do have one of those goofy looking Corbin seats for this bike. Like all Corbins, hard as a rock and with low "superbike bend" 'bars, puts me too far back for comfort, though my daughter much prefers the Corbin when she's back there.. I can get about 30 minutes on stock seat before squirming; think P.O. shaved foam down to fit stubby legs as there is a good bit of contact cement on underside. "Airhawk" inflatable cushion works well if you can get past that sensation of floating around on top of the seat. Best seat ever? swap meet $40 "pillow" seat for my 2000 cop H-D Road King with thick sheepskin cover. Cool in hot weather, warm in cool weather, no sweaty butt burn. Avoid getting it wet! Clean/ dry it with air hose
