Tiger 955i 2002 weak charge
Pspec
Today, 08:15
Nov 2, 2018
8
52
Uk
Tiger 955i
Hi all
I'm having a charging issue i'm hoping someone maybe able to shed some light on ...
I put my charger/stress tester on the battery it's a new battery so tested fine....flicked the stress test switch again fine.. Then started the bike and it showed as weak charge. ....
Next step was research
Stator, rectifier and rotor
Found ways to test the stator and rectifier but they seemed to test fine....
So the rotor is just a magnet and there's on reason why it would become demagnetized...
So did I do my tests incorrectly ? ? Or could it be something else....
I did a wee video of my tests so if anyone can find any faults with them please point them out..
Rectifier test Rectifier test
Stator test Stator test
I've now run out of ideas so any help would be great
Thanks ; ( ......
Greyfell
Proud Nerd
Riding for 4 Years
Today, 00:15
May 4, 2016
2,722
292
64
Northern California
Stephen
Next step is to check your earth/ground connections. Your test of the battery checked the battery at the posts, but your bike's indicator is checking at the starter switch, or at the starter, so there may be a loose (or corroded) connection between the battery and the point at which the indicator measures.
hemibee
Texas Tiger
Riding for 51 Years
Today, 02:15
Sep 28, 2010
11,146
845
Panorama Village, Texas
Tony
2013 Tiger 800XC
I would first check, as Greyfell said, for a loose ground.
shanered6
Time for adventure
Riding for 45 Years
Today, 08:15
Apr 5, 2011
6,583
563
52
Turriff, Aberdeenshire
shane llywarch
Moto Guzzi Stelvio 1200 ntx
what are the issues you are having ? ... flat battery ? poor strting ? weak lights ?
Pspec
Today, 08:15
Nov 2, 2018
8
52
Uk
Tiger 955i
Hi all
Battery isn't charging probably.... If the bike is left without starting for a week it won't start and that's driving without light so that's when I tested the Charge and the needle only went as far as the yellow and read weak. now the darkness has arrived that will only get worse...
Thanks for the ideas.... i'll trace the ground from the alternator to the battery and then from the battery to the starter and check all the grounds...
Fingers crossed
DaveM
Rock & Roll
Riding for 47 Years
Today, 09:15
42,620
1,257
Port Elizabeth
Dave
Speedmaster
It does sound like you might have a bad connection someplace.
shanered6
Time for adventure
Riding for 45 Years
Today, 08:15
Apr 5, 2011
6,583
563
52
shane llywarch
The early tiger 955i with light switch had a weak rectifier it was improved on the later ones with no light switch and had an improved generator , i would see if the recifier is getting warm when the bike is running !
Pspec
Today, 08:15
Nov 2, 2018
8
52
Uk
Tiger 955i
Cool I'll check that out as well.......
Oh some other info I should have posted
With bike running
Charge volts 13.5V (other people seem to be saying should be around 14.5V )
Used an amp clap around positive wire on battery...... 8 amps ...... lights on drops to 1.4 amps
Bike Manuel said the alternator should be 40 amps
shanered6
Time for adventure
Riding for 45 Years
Today, 08:15
Apr 5, 2011
6,583
563
52
shane llywarch
ye thats starting sound like either generator or rectifer !
hemibee
Texas Tiger
Riding for 51 Years
Today, 02:15
Sep 28, 2010
11,146
845
Tony
2013 Tiger 800XC
Yes, the voltage from the alternator should be ~14.5 volts.
keystiger
The Joker
Riding for 42 Years
Today, 02:15
Mar 24, 2009
6,709
469
52
The SWAMP
Adrian
2005 Triumph Tiger, British Racing Green--the fastest color
Seems there is a rectifier upgrade thread here......someplace.......
OH YES-- here it is in the "Cheapskates Garage!!!" --- FYI I STILL USE that same Tiger coffee mug EVERY day
cheapskates voltage fix
Pspec
Today, 08:15
Nov 2, 2018
8
52
Uk
Tiger 955i
I let the bike run for 5 mins to warm up stuck my finger on it and burnt my finger so thought I would use a more scientific method.
used one of those laser temp guns and it clocked 58c / 136F
the problem now I don't know what the temp should be.... have you any idea..
on my first post I put a link of a video of me testing the Rectifier it seemed to test ok do you know If I did something wrong..
Pspec
Today, 08:15
Nov 2, 2018
8
52
Uk
Tiger 955i
the earths seem good no corrosion ….. was kind of hoping that would have be the prob
keystiger
The Joker
Riding for 42 Years
Today, 02:15
Mar 24, 2009
6,709
469
52
The SWAMP
Adrian
I honestly am not certain what temp it should run at........
Perhaps a call to the local dealer might help
shanered6
Time for adventure
Riding for 45 Years
Today, 08:15
Apr 5, 2011
6,583
563
52
shane llywarch
Well im pretty sure it should not be running that hot !! usually a sign of shorting inside the unit !
keystiger
The Joker
Riding for 42 Years
Today, 02:15
Mar 24, 2009
6,709
469
52
The SWAMP
Adrian
Sounds like time to replace that thing
Pspec
Today, 08:15
Nov 2, 2018
8
52
Uk
Tiger 955i
Hey ......
I had to put fixing this on hold for a while but now back at it.
So I found the problem and it was the fuse box ..
This could also be the problem that a lot of others are experiencing with having a 1 volt drop in the wiring loom .
I did a wee video for the 1 or 2 people that may want to see the tests I did working this out.
Video of my wiring loom test..... Final wiring loom test
Fun stuff ; )
Qship
Riding for 40 Years
Today, 04:15
Feb 25, 2014
4,290
478
Steve
'17 Tiger Explorer XRT
Glad you were able to finally get it sorted out.
Get out and ride now. If the weather cooperates, of course.:beer:
Pspec
Today, 08:15
Nov 2, 2018
8
52
Uk
Tiger 955i
Yep already been benefiting from these flukey sunny days
(y)(y)
