Valve Stem Cap
sikatri
Yesterday, 23:39
May 25, 2019
1,082
122
61
Houston
2005 Triumph Thruxton 900
I was doing my pre-ride check and after putting a few lbs of air in the rear tire I screwed on the valve stem cap. As I was getting it tight I heard a “psssst” sound on the last turn before it bottomed out. Tried it again several times and the same result. The front doesn’t do it. I looked at the stem cap and it looks a bit different inside like there was something in there.6DC6D721-467F-4367-8C2A-DEF997DFFA20.jpeg
I backed it out a bit, but I’m afraid it might come off sometime. Is it time for a new cap or see if a small o-ring would work?
RockyDS
Riding for 51 Years
Yesterday, 22:39
Oct 26, 2019
180
42
66
Rocky Mountains, Canada
dualsport/adventure
I think there was likely a seal or o-ring in there that's been lost.
Rocky
Still Rocking
Riding for 29 Years
Today, 01:39
Jan 28, 2006
19,666
893
83
Halifax
Rocky
2006 T100 Bonneville
Unless it's some sort of "special" cap I would toss it and get some new ones. They're pretty cheap so why bother with a defective one.
They probably come is a small blister pack and it's always good to have spares.
sikatri
Yesterday, 23:39
May 25, 2019
1,082
122
61
Houston
It appears to be a custom Union Jack one. Not original, but cute. I may look for an o-ring.
RockyDS
Riding for 51 Years
Yesterday, 22:39
Oct 26, 2019
180
42
66
dualsport/adventure
Failing that, you could just squeeze some silicone sealant down the end and smooth it down to make your own seal. That would allow the cap to tighten down. It's only a dust cap, not an air seal after all. Make sure the sealant dries before screwing it on though - you wouldn't want it to get stuck on.
sikatri
Yesterday, 23:39
May 25, 2019
1,082
122
61
Houston
O-rings worked. No sound of valve being pressed and air leaking. Snug too.
Rocky
Still Rocking
Riding for 29 Years
Today, 01:39
Jan 28, 2006
19,666
893
83
Halifax
Rocky
Great that it worked TUP
