Wobble Question
Gear1
Riding for 3 Years
Today, 06:10
Jul 17, 2020
53
17
80
Pagosa Springs, CO
Craig Taylor
20218 Triumph Bonneville T100
A question for the Triumph brain trust: my 2018 Bonneville T100 will wobble when i aggressively straighten up the bike when exiting a turn. Below 60 mph the wobble damps out after 3-4 cycles. At higher speeds it takes 5 -6 cycles to damp out. I can also cause a wobble by a small but sharp push on either hand grip. Obviously I can damp the wobble by firmly grasping both handgrips. I’ve been reluctant to test this above 80 mph, as it appears that the wobble might go unstable and actually get worse rather than damping out. Is there anything that can be done about this or is it the nature of the frame and suspension design?
Craig
Vector
Riding for 51 Years
Today, 05:10
Apr 10, 2020
676
97
NV
Gary
2022 Street Twin
What tires are you running, what condition are they in?
Gear1
Riding for 3 Years
Today, 06:10
Jul 17, 2020
53
17
80
Pagosa Springs, CO
Craig Taylor
Sorry, I omitted this, Vector. Avon Storm 3D, front 110/80-ZR18 (10mm wider than the stock Pirelli front, same diameter), rear 150/70-ZR17 (stock size). Tires are new this spring, approx 1000 miles, wearing very evenly, and well balanced.
Craig
Vector
Riding for 51 Years
Today, 05:10
Apr 10, 2020
676
97
NV
Gary
2022 Street Twin
Did you make any other changes?
Gear1
Riding for 3 Years
Today, 06:10
Jul 17, 2020
53
17
80
Pagosa Springs, CO
Craig Taylor
No other changes. However I have been riding a bit more aggressively as the Avon tires inspire a great deal more confidence than the OEM Pirellis. The Avon front tire is a bit heavier due to the slightly larger size and radial construction; because of this it requires a bit more counter steer push on the handlebar to get the bike to turn into a corner. Perhaps this is the cause along with a bit of frame flex?
Craig
dacvulcan
New Member
Riding for 55 Years
Today, 08:10
Jun 17, 2022
6
74
Northern Virginia
Dennis
2022 Triumph Bonneville T100 Gold Line
Craig
I have a new T100 Gold Line and when I take my left hand off the bar to wave I feel slight shaking and also wonder if it is the chassis design or the stock Pirelli Phantoms. I have the feeling that is I took both hands off it would tank slap.
