dearborn
- Local time
- Today, 08:13
- Sep 29, 2015
- 261
- Points
- 57
- Age
- 75
- Location
- Dearborn Michigan USA
- First Name
- Doug
- 1996 Thunderbird, 1975(ish) Norton Commando
- Riding Since
- 1965
On another thread here, I wondered that since igniters controlled spark, dwell, timing, etc, whether there might be a performance gain from swapping the Thunderbird/Adventurer/Legend/Sport unit for one from, say a Trophy or a Speed Triple of the same series. Well, maybe not- from the official factory dealer service manual; "On Thunderbird, Thunderbird Sport & Adventurer, (no mention of Legend), the side stand switch is connected to the igniter in a different way to all other models as no side stand relay is fitted. In place of the relay, there are 2 "enable" lines to the igniter. One goes directly to the side stand switch and one directly to the neutral switch. The engine will run if either are switched to earth." And further; "The igniter evaluates information from the crankshaft sensor which is received in the form of electronic pulses. From the received pulses, the igniter calculates the output required from the coils. The basis for the calculations come from the pre-programmed ignition parameters inside the igniter unit. The calculations include; dwell angle, ignition timing, (and) firing order" So, we know the different igniters from different models are wired differently, at least for the side stand switch and neutral switch. There may, (or may NOT), be other wiring differences. And, we know that dwell and timing curves are also different. So, we can say that disregarding the side stand and neutral switch issues in an igniter from a higher performance model using the "GILL" components may possibly result in performance gains, or may lead to a slobbery, horrible running bike. And who knows if swapping igniters could result in internal circuitry damage in the ridiculously expensive igniters. There is an aftermarket igniter available from "Vectriq" at www.regulatorrectifier.com for about $375 USD which promises better performance for Thunderbird/Sport/Adventurer, (Legend?).
