dearborn
- Local time
- Today, 01:44
- Sep 29, 2015
- 261
- Points
- 57
- Age
- 75
- Location
- Dearborn Michigan USA
- First Name
- Doug
- 1996 Thunderbird, 1975(ish) Norton Commando
- Riding Since
- 1965
My '96 Thunderbird has been 100% reliable in the 7 or 8 years I've owned it- ZERO issues! UNTIL...last week while crawling along in annual Detroit "Dream Cruise", (50,000+ cars, 17 miles long, million+ spectators!), it got REALLY hot, stalled, would not start. Let sit for about 2 hours- started right up. Rode about a mile to my brother's house, turned it off. After about 45 min. started right up, ran about 5 minutes, died. Cranks, no start. Pushed back to brothers, let sit about 2 hours, starts right up, but don't want to risk being stranded. Came back with pickup next day, unload it at home, starts right up, runs 4-5 minutes, dies. Fuel starvation?- tank about 3/4 full, but no visible flow at in-line filter after fuel tap. Disconnect fuel line at tap, connect drain hose to tap- unrestricted flow. Remove fuel tank, found about a teaspoon of debris packed around reserve pickup tube. Clean tank & fuel tap, replace in-line filter. Cold engine, unrestricted fuel flow to filter, starts up, runs about 5 minutes till hot, dies. No spark. Check coils- all ok, readings within spec on both Haynes and factory Triumph workshop manuals. Check pick-up trigger- all within spec. Only thing left is igniter and no way to check. Igniters control timing, etc, so different models used different igniters. Anyone have experience with aftermarket suppliers? Or swapping igniters from different models? Anyone repair them?
